simulated IO
I am trying to find a way to reset simulated signals in rapid. Does anybody knows if this is possible?
thanks.
  • Did you tried the "Reset DO_1;" (DO_1 is the Digi Output signal)?
    I`m using it and it works.
    Regards Szily
  • SetDO doSim,0; normally works also.
