Strange configuration problem
why do I get this msg: Jump failed. The stored configuration [-1,-1,0,1] is not valid.
Is this really a config which is not valid or a application error?
I can jog to a position, store it, move to it, but not jump to it, then I get this error. It is not possible to get a proper config, but while teaching I got one (the above). At some positions it is even not possible to get the config dialog open. This worked much better in the last version, although I had problems there with configs too.
All the best,
Lohengrin
All the best,
Lohengrin
  • Hi,
    Which robot are you using?
    Kind Regards
    Fredrik
    Fredrik Syr?n
    Program Manager
    ABB Automation Technologies
  • Hi Fredrik,
    I am using a 6600/2.55/175/M2000.
    I found out some more: I had a tool as a component group attached to the robot, and could not jog linear with it anymore. Now I detached the tool and I can jog linear with the same tooldata, can teach targets, but don't get a config for them again. The dialog shows up and shows the former config, but I cannot choose a new one and the target gets unusable.
    All the best,
    Lohengrin
    Lohengrin2006-3-21 14:16:30
    All the best,
    Lohengrin
  • Hi Lohengrin,
    I will send you an email with an updated file that will correct your problem.
    If there are any other users experiencing the same problem, please send an email to fredrik.syren@se.abb.com and I will provide you with this fix. (We will publish this fix on this web site as soon as it allows for file uploads).
    Kind Regards
    Fredrik
    Fredrik Syr?n
    Program Manager
  • Hi Fredrik,
    thank you so much for this lightning fast fix, it works perfectly! I can jog linear with that tool again and teach targets with proper configs and can change the configs. Perfect!
    (And I can still hold my deadline this evening, thanks a lot!)
    All the best,
    Lohengrin
    All the best,
    Lohengrin
