variables not defined
esxamar
I need crate a instruction in a mainmodule with a variable not defined.
For example; reg1:= AAAA ;
The variable AAA is defined in a module that i want load later with the instrucion StartLoad.
Now when I load the mainmodule with the instruction re1:=AAA; i have a syntax error.
Is possible to add any argument to avoid the syntax error and execute the programa normally,
You can use the system parameter "Bindref". This will help you out.0
