RobotStudio 4.0 crash issues
I'm having a problem with my RobotStudio 4.0 installation on a Dell M6400 laptop running Windows XP Pro. The program opens quickly, but as soon as I add a robot or any geometry things start running very slowly with the program hanging for tens of seconds before I can interact with it again.
I tried starting a 140 controller and got the following error message:
Assertation failed!
File: D:integr
el4_0.xxiofclasslibeioeio.c
Line 2036
status == OK
My
drive is a DVD drive, which is empty.
Creating a fresh 140 controller still gives the same error.
This problem occurs for brand new stations or old stations I've used successfully in the past.
Could there have been a recent Windows update that is interfering with RobotStudio? I haven't installed any programs recently since this behavior started.
Thanks,
Jon
Hi Jon,Please try to generate a new key.id on the virtual controller you want to start.(Setup Controller>Change Controller>Select system and click Properties>Directly click Finish in the wizard.)Then set current robot and try again.Best regards,
Anders Jahnberg
ABB Robotics0
- 858 RAPID Programming
