is it a bug when multiple TCPs used
xeratule
May this be a bug of the robotstudio?
My program version is 5.14.01
Edit: By the way when I run the simulation it operates well. This bug just complicates the progress of the design.
Thanks in advance.
xeratule2012-11-02 12:58:19
R&D Electronics Engineer
yeah it was a bug but somehow when I restarted my computer it's fixed.R&D Electronics Engineer0 -
I'm glad that the problem disappeared. We will keep our eyes open and try to look for the problem.
RobotStudio 5.15 has been released and I recommend you to upgrade. It can be downloaded from http://www.abb.com/roboticssoftware.
You
can use 5.14 in parallel with 5.15 as it is installed side-by-side.
The same license is used. Stations created in 5.15 can be loaded into
5.14 if you follow the guideline in Release Notes / What's New. Of
course, stations from 5.14 and earlier can be loaded into 5.15.
ABB0
- 365 IRC5
- 84 OmniCore
