Smart Component mechanism
radekck
I've had i problem with Event Manager, so I made with RS tutorial my vacuum gripper with SC. It works perfect. I wanted to use that and make a mechanism gripper (kind of). I put signals that change its joints and and signals for attaching. Change of the joints works, but the item isn't attached. I can add, that the mechanism is attached to positioner.
Here are my signals:
The blue gripper had left the part on the positioner and I want the lightblue-grey gripper to attach the lamp. But When I turn on the signal to attach, only mechanism position is changed (that lightblue-grey gripper is expanding), but the part isn't attached to it. What can be a problem? The bindings are left like in the tutorial, as well as in the gripper on positioner as in the vacuum gripper.
Thanks,
Radek
Radek
I solved that problem: The lightblue-grey gripper was bad kind of mechanism, i changed it to Tool. Now the problem is solved.Radek0
