Error
dallas72
What is wrong?
What operation did you do prior to the error?
I got some new information from my developer colleagues: The fault is known and will not affect RobotStudio usage. You can continue using RobotStudio as normal. The error will be fixed in 5.15.01 (scheduled for April A'13)
i have RobotStudio 5.15 64bit.
It does not matter if I press oneClickConnekt or if I Create Empty Station to get that error message.
Thank you so much for your help.
- 348 IRC5
- 847 RAPID Programming
- 21 AppStudio
