ABB Robot Studio Services
Hi Matt,
The IRB 1400 is supported by IRC5 controller that can be programmed using RobotStudio 5.15. You can download RobotStudio 5.15 from
http://www.abb.com/roboticssoftware. There is a 30-day trial that should
give you enough time to analyze the reach of the IRB 1400. Since the IRB 1400
is not available for new orders with the IRC5 controller, it is not visible in
the gallery of available robots. But the robot library of the IRB 1400 is
installed with RobotStudio 5.15. You need to browse to the file using
"Import Library" to get it into your station. Then use "Robot
System -> From Layout" to create the matching controller system.The RAPID code of the IRC5 controller is compatible (in most
cases) with the S4/S4C/S4C+ controller but not the configuration files (SYSPAR
/ CFG). This means you can actually offline program your old robot using
RobotStudio 5.15. Create your program, save the module and load it into the
real controller.RobotStudio 5.x has a much more attractive business model
than the RobotStudio for S4. RobotStudio 5.x is available with an affordable,
annual, subscription.
Henrik Berlin2012-12-13 14:34:53Henrik Berlin
Great info, thanks. This is a much better option for someone who does all their own machine building/commissioning. I will give the free download a try and let you all know how it goes!Thanks again,-matt0
