Geometry import problem(s)
Hallbeck
Hi!
I'm having a bit of a headace importing 3d models from our mechanic design team. See the detailed error description below. The only error I can find in the description is "Error : Translation aborted due to out of memory allocation problem" which appears a few times. Is this memory allocation problem hardware or software related?
Im running RS5.15 on win7(32bit) enterprise on a computer with specs that meet and go way beyond the minimum requirements for RS5.15
Thanks in advance, keep up the good work!
David
RobotStudio .NET exception: --------------------------------------------------------------------------------
Translator Name : Spatial InterOp Connect ( Version : 23 0 0)
System Name : Windows_NT
Machine Name : M6600-6ZLKBT1
User Name : KS04212
Source System : Inventor
Destination System : ACIS
Input File : C:Usersks04212DesktopBlstercell_080439_V2.ipt
Start Time : Fri Dec 14 08:13:52 2012
Message : === Translation Options ===
Message : TranslateAttributes : true
Message : TranslateHiddenEntities : false
Message : Representation : BRep+Assembly
Message : Healing : true
Message : ===========================
-------------------------Source File Header Information-------------------------
Modification Date : Wed Dec 12 10:03:16 2012
File Name : "Utredning Pick N Place/ fixturer / Gripdon - Substitute"
Author : "JC"
Organization : "CSM"
Version : 2012
Comment :
Units : MILLIMETER
Document Type : Part
Source Document Preprocessing Result : Success
Target Document Preprocessing Result : Success
Start BRep
Target Document Postprocessing Result : Success
Target Document Postprocessing Result : No Entity to Translate
---------------------------Document Conversion Summary--------------------------
Finish Time : Fri Dec 14 08:13:53 2012
Translation Result : Aborted
Base exception: GeoException
User Name : KS04212
Author : "JC"
Version : 2012
Comment :
Units : MILLIMETER
Start BRep
Server stack trace:
at RobotStudio.Services.Geometry.ModelerService.Import(String bstrImportFileName, GeoPart pPart, CADFormat fmt, Boolean bTranslateHidden, Boolean bHealing, IProgressCallback pProgress, String bstrLogFile)
at RobotStudio.API.Internal.AssemblyModeler.LoadPart(GraphicComponent parent, String fileName, DetailLevels lods, Boolean surfaceModel, Boolean translateHidden, Boolean healing, IProgressCallback progressCallback)
at ABB.Robotics.RobotStudio.Stations.Part.Load(String fileName, IProgressCallback progressCallback, Boolean surfaceModel, Boolean translateHidden, Boolean healing, DetailLevels detail)
at ABBInternal.StationLogic.ComponentServices.<>c__DisplayClass12.<<ImportComponents>b__e>d__15.MoveNext()
Exception rethrown at [0]:
at ABBInternal.GUISupport.ProgressDialog.ShowWhile(Func`1 work)
at ABBInternal.StationLogic.ComponentServices.ImportComponents(IEnumerable`1 fileNamesOrDocInfos, Boolean importGeometry, IHasGraphicComponents parent, Nullable`1 position, GeoImportOptions geoOptions)
David
User Name : KS04212
Author : "JC"
Version : 2012
Comment :
Units : MILLIMETER
Start BRep
User Name : KS04212
Author : "JC"
Version : 2012
Comment :
Units : MILLIMETER
Start BRep
Server stack trace:
Hi David,
What's the size of the CAD-model? The CAD-converter error message indicates there is a problem with memory allocation. Do you have access to a PC with Windows 7 or 8 64-bit version? Then you can use the 64-bit version of RS that has better support for large CAD-models since it can address more memory.
Hi!
The cad model is no bigger than 51Mb.
According to our IT guys a 64bit OS is what will happen if we cannot find any other solution...
David
Hi David,
Please get in touch with your local ABB representative that can forward your issue to our tech support, see http://www.abb.com/product/ap/seitp327/a2073867d4b9c570c1257991004dd00a.aspxS
If you are located in Sweden, you can call our RobotSupport that will help you log the problem, see http://www.abb.com/product/ap/seitp327/d4fc82d62e864f20c125762e004cd845.aspx.
Ok, thanks.
- 365 IRC5
- 84 OmniCore
