Axis Limit increase
Nata_lia
I tried to increase the Axis limit of 4th Axis in ABB safe robot from + - 300 degrees to + - 315 degrees. It worked for the first time. Then I downloaded the safety controller to the controller and now the 4th axis does not go beyond its prest limit value, +- 300 degrees.
Anyone have any idea about it. PLease help
Nata
Nata
Hello,If I understand correctly, you did the following:-- Using the Configuration Editor, adjusted the limits of axis 4 using the Upper and Lower Joint Bounds, under the ARM parameter, (in radians)-- Setup a safety controller configuration and setup the Safe Axis Range (in degrees) usin g the Safe Move Configurator,-- Then when testing, you noticed that the axis 4 stopped (from the Safe Move stop?) at 300 degrees,Is that correct?Kind Regards,Steve0
- 858 RAPID Programming
