Missing External Axis Value
I'd like to use 2 robots on 2 conveyors. With one of these is ok, but when I'm trying to simulate with two robots I have error number 40512 about missing external axis value.
HEEELP
First check that you have a valid (<9E9) eax value on the conveyors external axis positions in the robtarget. RS will usually solve this for you when you teach the targets, but if that doesn't work, your station/system probably is wrongly configured. Please check the demo station that is provided with RS (2 robots on one conveyor) and read the RS-documentation how to setup the conveyor
magu0 -
i've found answer for my problem but i have no idea where i Controller Browser..0
Don't know if that is what you meant but in RobotStudio 5.15 the Controller browser is under the Controller tab/ribbon.
John
Developer Center0 -
Again this same problem about missing axis value
How can i change it in the first path?
EDIT: I changed it in RAPID, i think its ok now
aldoraine2012-12-21 13:17:020
- 365 IRC5
- 84 OmniCore
