Rev. Counter Update Position
petorin
We have a robot that could not go to zero position in axis 2 because of the building structure. Is there any way to change the calibration position (about 40 degrees)?
Thanks for your help..
Be aware of that you can calibrate axis by axis (no need to have all axis in zero just the one you select in rev counter update).Per Svensson
Consat Engineering0 -
Hi again,
Thank you for your information but the real problem is I cannot move second axis to zero position because of the height no matter where the other axes are. So I think i need to change the rev. counter update position of the second axis.0
- 361 IRC5
- 78 OmniCore
- 852 RAPID Programming
- 30 AppStudio
