Problems with the 5.15 Robotstudio
Dear Sir or Madam,
everytime I try to load an existing station (given by a collegue) I get the following errors. I tried removal and reinstallation 2 times. No chance to get it working. The station is in 5.15 thus I need the 5.15 working. The 5.14 was working fine. Trialperiod is at 24 days at the moment.
Is there any solution to this problem except changing the robot to KUKA? :-)
thx in Advance ...
Details of crash see below.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
at RobotStudio.Services.Controller.VcConfigurationData.GetRobotSingleName(String mechUnitName)
at RobotStudio.Services.Controller.VcManager.GetFirstFlangeForMechUnit(RsMechanicalUnit mechUnit, Matrix4& matOffset)
at RobotStudio.Services.Controller.ControllerService.GetFirstFlangeForMechUnit(RsMechanicalUnit mechUnit, Matrix4& offset)
at ABB.Robotics.RobotStudio.Stations.RsMechanicalUnit.GetFlange(Matrix4& offset)
at RobotStudio.API.Internal.GfxUpdater.UpdateAttachments()
at RobotStudio.API.Internal.GfxUpdater.Update(IApiGfxModel gfxModel, TemporaryGraphicCollection tmpGfx)
at ABB.Robotics.RobotStudio.Stations.Forms.GraphicControl.Update()
at ABB.Robotics.RobotStudio.Stations.Forms.GraphicPicker.GraphicView_MouseMove(Object sender, MouseEventArgs e)
at System.Windows.Forms.MouseEventHandler.Invoke(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
at RobotStudio.Core.GraphicView.GraphicView.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
a__
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
RobotStudio
Assembly Version: 5.15.4992.261
Win32 Version: 5.15.4992.261
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.exe
GUISupport
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/GUISupport.DLL
System.Xml
Win32 Version: 4.0.30319.233 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System
Win32 Version: 4.0.30319.296 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
Win32 Version: 4.0.30319.298
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
Win32 Version: 4.0.30319.298 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
Win32 Version: 4.0.30319.278 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.282 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Microsoft.Licensing.Runtime2.0
Assembly Version: 3.1.1925.4
Win32 Version: 3.1.1925.4
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Microsoft.Licensing.Runtime2.0.DLL
StudioAppFramework
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/StudioAppFramework.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ABB.Robotics.RobotStudio.DLL
ABB.Robotics.RobotStudio.Environment
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ABB.Robotics.RobotStudio.Environment.DLL
Microsoft.CompilerServices.AsyncTargetingPack.Net4
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Microsoft.CompilerServices.AsyncTargetingPack.Net4.DLL
System.Xml.Linq
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
RobotStudio.resources
Win32 Version: 5.15.4992.0261
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/RobotStudio.resources.DLL
StudioAppFramework.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/StudioAppFramework.resources.DLL
Interop.CmSupport
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Interop.CmSupport.DLL
System.Configuration.Install
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration.Install/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
RobotStudio.Resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Resources.DLL
Microsoft.Licensing.Utils2.0
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Microsoft.Licensing.Utils2.0.DLL
Microsoft.Licensing.Permutation_6e3db_2.0
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Microsoft.Licensing.Permutation_6e3db_2.0.DLL
Slps.Distributor.Client
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Slps.Distributor.Client.DLL
Slps.Distributor.Contracts.Client
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Slps.Distributor.Contracts.Client.DLL
Slps.Distributor.Core
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Slps.Distributor.Core.DLL
System.ServiceModel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
SMDiagnostics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.Runtime.DurableInstancing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.DurableInstancing/v4.0_4.0.0.0__31bf3856ad364e35/System.Runtime.DurableInstancing.dll
RobotStudio.Resources.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/RobotStudio.Resources.resources.DLL
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
GUISupport.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/GUISupport.resources.DLL
ScreenMakerAddin
Assembly Version: 5.15.261.0
Win32 Version: 5.15.261.0
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Addins/ScreenMakerAddin.dll
EPSAddIn
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Addins/EPSAddin/EPSAddin.dll
SafeMove
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Addins/SafeMove/SafeMove.dll
ABB.Robotics.SafetyController
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Addins/SafeMove/ABB.Robotics.SafetyController.DLL
ABB.Robotics.RobAPI.Interop.RobHelperFactoryLib
Win32 Version: RW 5.15.0261.00
CodeBase: file:///C:/Windows/assembly/GAC_32/ABB.Robotics.RobAPI.Interop.RobHelperFactoryLib/1.0.0.0__1da709b7d1f14b7b/ABB.Robotics.RobAPI.Interop.RobHelperFactoryLib.dll
ABB.Robotics.RobAPI.Interop.RobControllerLib
CodeBase: file:///C:/Windows/assembly/GAC_32/ABB.Robotics.RobAPI.Interop.RobControllerLib/1.0.0.0__1da709b7d1f14b7b/ABB.Robotics.RobAPI.Interop.RobControllerLib.dll
ABB.Robotics.RobAPI.Interop.RobDataLib
CodeBase: file:///C:/Windows/assembly/GAC_32/ABB.Robotics.RobAPI.Interop.RobDataLib/1.0.0.0__1da709b7d1f14b7b/ABB.Robotics.RobAPI.Interop.RobDataLib.dll
ABB.Robotics.RobotStudio.Controllers
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ABB.Robotics.RobotStudio.Controllers.DLL
RobotStudio.Services.RobApi
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Services.RobApi.DLL
StationManagement
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/StationManagement.DLL
Controller
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Controller.DLL
RobotStudio.UI.Controller
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.UI.Controller.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ABB.Robotics.RobotStudio.Stations.DLL
ABB.Robotics.Math
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ABB.Robotics.Math.DLL
Ionic.Zip.Reduced
Assembly Version: 1.9.1.5
Win32 Version: 1.9.1.5
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Ionic.Zip.Reduced.DLL
RobotStudio.Core.Interop
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Core.Interop.DLL
OnlineManagement
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/OnlineManagement.DLL
RobotStudio.Services.Graphics
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Services.Graphics.DLL
ABB.Robotics.RobotStudio.CADConverter
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ABB.Robotics.RobotStudio.CADConverter.DLL
RobotStudio.Services.Simulation
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Services.Simulation.DLL
RobotStudio.Services.Modeling
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Services.Modeling.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Services.Controller.DLL
RobotStudio.Services.RapidSync
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Services.RapidSync.DLL
ToolWindow
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ToolWindow.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ABB.Robotics.RobotStudio.Stations.Forms.DLL
Transfer
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Transfer.DLL
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
RobotStudio.UI.Controller.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/RobotStudio.UI.Controller.resources.DLL
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
RobotStudio.UI.Rapid
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.UI.Rapid.DLL
ActiproSoftware.Text.Wpf
Assembly Version: 11.2.550.0
Win32 Version: 11.2.550.0
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ActiproSoftware.Text.Wpf.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Services.Rapid.DLL
RobotStudio.UI.Rapid.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/RobotStudio.UI.Rapid.resources.DLL
StationManagement.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/StationManagement.resources.DLL
GraphicCommands
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/GraphicCommands.DLL
SimulationCommands
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/SimulationCommands.DLL
Wizards
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Wizards.DLL
ElementCommands
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ElementCommands.DLL
GearboxHeatPrediction
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/GearboxHeatPrediction.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/Controller.resources.DLL
RobotStudio.Services.Geometry
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Services.Geometry.DLL
SmartComponentCommands
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/SmartComponentCommands.DLL
RobotStudio.UI.GraphicViews
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.UI.GraphicViews.DLL
GraphicCommands.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/GraphicCommands.resources.DLL
RobotStudio.UI.DataRecorder
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.UI.DataRecorder.DLL
SimulationCommands.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/SimulationCommands.resources.DLL
StationLogic
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/StationLogic.DLL
EventManager
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/EventManager.DLL
MechanismModeler
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/MechanismModeler.DLL
ABB.Robotics.RobotStudio.Documents
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ABB.Robotics.RobotStudio.Documents.DLL
GearboxHeatPrediction.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/GearboxHeatPrediction.resources.DLL
InstructionTemplates
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Addins/InstructionTemplates.dll
MultiMove
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Addins/MultiMove.dll
KIRTech.MultiMove.API
Assembly Version: 5.7.1688.10
Win32 Version: 5.7.1688.10
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/KIRTech.MultiMove.API.DLL
KIRTech.Core
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/KIRTech.Core.DLL
VstaServices
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/VstaServices.DLL
Microsoft.WindowsAPICodePack.Shell
Assembly Version: 1.1.1.0
Win32 Version: 1.1.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Microsoft.WindowsAPICodePack.Shell.DLL
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Microsoft.WindowsAPICodePack.DLL
System.Data.SqlServerCe
Assembly Version: 3.5.1.0
Win32 Version: 3.5.8080.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Data.SqlServerCe/3.5.1.0__89845dcd8080cc91/System.Data.SqlServerCe.dll
System.Data
Win32 Version: 4.0.30319.237 (RTMGDR.030319-2300)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Data.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Linq.dll
Anonymously Hosted DynamicMethods Assembly
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
ABB.Robotics.Controllers
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/ABB.Robotics.Controllers/5.15.261.0__1da709b7d1f14b7b/ABB.Robotics.Controllers.dll
ABB.Robotics
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/ABB.Robotics/5.15.261.0__1da709b7d1f14b7b/ABB.Robotics.dll
RobotStudio.Services.GraphicConverters
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/RobotStudio.Services.GraphicConverters.DLL
ElementCommands.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/ElementCommands.resources.DLL
ToolWindow.resources
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/de/ToolWindow.resources.DLL
ObjectToolControls
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ObjectToolControls.DLL
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
ElementToolControls
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ElementToolControls.DLL
ModellingToolControls
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/ModellingToolControls.DLL
Interop.TDxInput
CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.15/Bin/Interop.TDxInput.DLL
Microsoft.VisualStudio.Tools.Applications.AddInManager
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.200
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.Tools.Applications.AddInManager/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Tools.Applications.AddInManager.dll
Microsoft.VisualStudio.CommandBars
Win32 Version: 8.0.50727.4039 (QFE.050727-4000)
CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.VisualStudio.CommandBars/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.CommandBars.dll
EnvDTE
CodeBase: file:///C:/Windows/assembly/GAC/EnvDTE/8.0.0.0__b03f5f7f11d50a3a/EnvDTE.dll
ABB.Robotics.Adapters.IRC5
CodeBase: file:///C:/Windows/assembly/GAC_32/ABB.Robotics.Adapters.IRC5/5.15.261.0__1da709b7d1f14b7b/ABB.Robotics.Adapters.IRC5.dll
msvcm90
Assembly Version: 9.0.30729.6161
Win32 Version: 9.00.30729.6161
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
01000111
01000111
Hi Matrhic,
There seems to be an problem with a 'single' in the station. To analyze the problem in details, we need your station.
Please get in touch with your local ABB Robotics Service representative that can forward your issue to our tech support. Unless you already know who it is you can check http://www.abb.com/contacts.
ABB0
- 367 IRC5
