Open windows on TeachPendant in RAPID
in ScreenMaker
I thought TPShow was the solution to my problems, but it doesn't do what I thought it did.
Is it possible to make a RAPID program pull up menus on the TeachPendant automatedly?
For example, I'd like to display a page in the Control Panel > Configuration menu. Can RAPID navigate menus and show a specific screen?
I am not the right person to tell you about he limitations and possibilities of TPShow. But perhaps a custom screen for the FlexPendant created with ScreenMaker could be an option for you?
The RAPID instruction UIShow allows to open FlexPendant applications. You can provide an argument also.
The goal of this RAPID instruction is allows users either to launch their custom or system application. However, each application define how to handle the argument.BRCarlos Martinez
Is there a reference somewhere that tells the name/type of FlexPendant applications for use with UIShow?0
There is not documenation about the standard FP applications. Which one are you interested in opening?
Carlos Martinez
Control Panel > Configuration > Controller > Event Routine0
The Control Panel is not prepared to be opened and/or activated from RAPID into an specific view.
An option would be to create your own UI to make changes. Just need to check that FP SDK provides you access to the specific data you are interested on.Hope this helpsCarlos Martinez
Here is a link to the FPSDK Application manual which describes the standard views supported to be launched : http://developercenter.robotstudio.com/Index.aspx?DevCenter=ManualsOrFPSDK&OpenDocument&Url=../FPSDKAppManual/doc45.htmlThe same views holds good for UIShow from RAPID as well.Thanks,Abhishek0
- 367 IRC5
- 858 RAPID Programming
