Calculate Pose Value of the frame
Lin
Hi Guys,
The RAPID way is
pose pose1 := CalcRobT(jointtarget1, tool1 WObj:=wobj0);
Thank you.
Lingaa
sorry it is not pose it is robtargetrobtarget tgt1 := CalcRobT(jointtarget1, tool1 WObj:=wobj0);Lingaa0
HiYou can get the axis values from the joint taget using GetJointVal and then pass it into theForwardKinematics method, which returns a 4x4 matrix, which you can set on a robtarget.Hope it helps,Regards LarsLars Glud
Danrob A/S0
