duplicated search instructions in rapid editor [ArcWelding PowerPac]
Hello there,
I got a strange problem (hopefully not so strange to you)
I have created an search instruction (search_1D) in arc weld power pack
When i press on the simulation button it will run down the program
But when i look at the rapid editor code there is a whole bunch of the same search instructions in it
Everytime i press the simulaton button, the search instruction in the rapid editor duplicate itself....
I have tried a lot of things and im getting low on options....
anybody got a clue?
jasper2013-03-05 16:10:26
Post edited by [Deleted User] on
Hi,AWPP sometimes has problems with updating the VC, when you make changes to the path.Delete the module in the VC and Synchronize again.Note that you have used ArcMoveAbsj, not a normal Airposition for a standard system. Used for multimove.0 -
Thanks for the adviceI have tried to put the data in a new module, trow all the data away an syngronise again, it did't work out..Yet with an older version of my station, on another computer the duplication is gone.And i think to know wy:in the picture below you can see that the search_1D command is now highlighted in bluei gess it recognizes the command and it turns blue somehow?0 -
Which RS version are you using?
There was a problem in RobotStudio 5.15 that made RS fail to recognize "hidden" instructions. I suppose the Search1D instruction might have been one of them. Try installing RS 5.15.01 and see if it helps.
Ok, i was indeed using the 5.15.00 version
I have upgraded now
Thanks for your comment
- 348 IRC5
- 847 RAPID Programming
- 21 AppStudio
