"Disp.xml" Import
Linda
I met a problem when I import the "Disp.xml" through the "Instruction Template Manager".
The robot is IRB4400/10L. It is always invalid. I don't know why.
But in a empty station, I can import this "Disp.xml" successfully.
Here is a pic to show the error. Seems some problem with the "Bead1'?
It is the validation that not is correct, the templates will work even if you get the message that they are not valid.
But on your Picture I can see that you have mutiple "Move Instruction Descriptions" for the dispense instructions, which not is a good idea.Best regards,
ABB Robotics0
