Configurations...
yesterday I install RobotStudio 5.07. Today I started to really use that.
But when I try to use "Configurations..." function in elements window. I wil get to Output message window "Unknown Error: Configurations". Same thing for example with "Teach Move Instruction" => "Unknown Error: Teach Move Instruction" and "Set position"... etc.
When I Install RobotWare/RobotStudio (Repair selection) again and reboot my pc. Everything works fine little time and then same problem. Today I have done that allready two times. What to do?
PC: IBM ThinkPad R51
In same pc I have RS 3.2 which I have use before succesfully.
Pekka
Hi Pekka,
If it is the IRB6600 you have problem with, read the thread "Configuration problems for IRB6600".
If it's another robot model you have problem with, I recommend that you cold start the controller (or creates a new one) and see if that helps.
In a few weeks we will release RS 5.07.01 there the configuration functionality is improved.
ABB Robotics0
