Modifying Named Points
Hello, can someone explain to me how to modify a named point (robtarget) in Robot Studio Online (RSO)? I have been leaving all points as asterisks (*) so I can modify in RSO but this is becoming confusing. I have tried everything I can think of with no success. Any advice is appreciated.
Thank you in advance.
Post edited by John Wiberg on
In RobotStudio Online? In that you'd have to do it manually in the text, and that is no gain.
However if you use ordinary RobotStudio it is easy.
Connect to the controller -> Go Offline
Sync the module to Station
In the Home tab, in the Paths & Targets browser, select all the inline targets you want changed.
Right click >> inline
Sync to VC
Open up the RAPID editor and save the module...
Tada, done.
It works the other way as well.
John
Developer Center1
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
