Path decleration
You can use an string declaration (array) to store the paths you want to execute.
Then you can use this proccall instruction:
PERS String path_stored{5}:=("path1","path2","path3","path4","path5");
PERS String path_execute:="path1";
%path_execute%;
So you can change the name of the path by
path_execute:=path_stored{5};
You can do it in a loop and when the string is empty the program is ready.
greetings
hi,
if i wanna change the name. i have to use the decleration PERS String path_execute:="path1"; %path_execute%;?
What you mean with a loop ?
Here is an example of how you can do it.
MODULEts
PERS String path_stored{6}:=["path1","path2","path3","path4","path5",""];
PROC Main_Rot()
MoveAbsJ [[0,20,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
FOR i FROM 1 TO 99 DO
path_execute:=path_stored{i};
IF path_execute="" GOTO end;
%path_execute%;
WaitTime 1;
ENDFOR
end:
PROC Path1()
MoveAbsJ [[0,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
PROC Path2()
MoveAbsJ [[45,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
PROC Path3()
MoveAbsJ [[90,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
PROC Path4()
MoveAbsJ [[-45,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
PROC Path5()
MoveAbsJ [[-90,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
ENDMODULE
You need an change the executed routine.
gr
hi,thanks for the answer.I dont understand the decleration after proc main.I mean:,,MoveAbsJ [[0,20,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;'', from where you get this decleration?0
