Wireless Connection
is there a way to connect to an IRC5 controller using a wireless access point or can RSO only us a connection from the ethernet port?
Shouldn't be any problem I have used a wireless access point from dlink(can't remember which one at the moment) connected directly to the serviceport.Per Svensson
Consat Engineering0 -
do i need to set a static IP address or is it usable with a DHCP network?0
If you connect to the service port you should be fine with dhcp.Per Svensson
I use an Asus wl-330gE for that. Small and reliable..
Hello Petjo, could you explain what settings you used on the Asus wifi adapter? Also were there any changes to the settings for the service port?0
I think I set the adapter to bridge mode and setup wifi to replicate the serviceport ip adress. No changes on the robotcontroller
Note that the service port is a DHCP server, if you want to use other ports you need the option PC Interface on the robotsRegards
Knud Erik Lindberg
Jorgensen Engineering0
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
