EDS file
tonio163
<font face="Arial, Verdana" size="2"><span style="line-height: normal;">Hello,</span></font><div style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant: normal; font-weight: normal; line-height: normal;">I have Ethernet/IP IO-Link of Balluff who communicate with irc5.</div><div style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant: normal; font-weight: normal; line-height: normal;">How to used the eds file balluff</div><div><font face="Arial, Verdana" size="2"><span style="line-height: normal;"><a href="http://www.balluff.com/balluff/MFR/fr/products/catalogue/products_downloads.jsp?id=BNI004A-210042">http://www.balluff.com/balluff/MFR/fr/products/catalogue/products_downloads.jsp?id=BNI004A-210042</a></span></font><br></div>
You do not use the .EDS file directly to configure an EthernetIP slave connected the the master in the IRC5. Refere to the EthernetIP application manual to read the whole information... it should be part of the robot delivery.
A short break out: open the EDS file to get the needed information for creating a "Unit Type" in the IO configuration of the controller...
If done you may define your unit on the EthernetIP and then your signals on this unit...
regards
regards
Christian0
