No license [Cutting PowerPac]
Today I downloaded and installed RobotStudio, Machining and Cutting PowerPacks on my home computer.
I knew I had 30 days to try it. I use RS at work but I wanted to try the power packs at home during the holidays.
RS and the Machining PowerPack worked fine but the Cutting PowerPack said it couldn't find a license once installed.
Any idea?
thanks,
Jet
Jet,
Janin Delorme, Ing. (P.Eng)
Today I downloaded and installed Cutting PowerPack again. This time on my working license at school. I can install all the powerpacks but the cutting one won't work. It says I have no license for it.I hope ABB will fix the problem or at least remove the PowerPack from the download page if it's not ready to be released.It doesn't look very good when a new PowerPack is advertised at the main ABB download page and it doesn't work.JetJet,
Janin Delorme, Ing. (P.Eng)0 -
There is no free grace period on the Cutting Power Pac that I am aware of. You must have a fully licensed version of RobotStudio with a purchased license for Cutting Power Pac or it will not work.<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The Cutting PowerPac 5.15 which will be released in a few weeks or so, will have a 30 day trial.Contact our license support if it does not work and they can help you out.0
i have a school license of robot studio 5.15, but i can not download the PowerPack i need it for the force control , anybody can help with a useful link to get the PowerPack installation0
I guess you're looking for Machining Powerpac
You may find it in the Robotstudio dowonload area ... http://new.abb.com/products/robotics/robotstudio/downloads
regards
regards
Christian0 -
Im having a simliar problem to Jetman, I'm running RS 6.00.01 with the latest version of Cutting powerpac.
"Failed to aquice license feature 'Cutting_PowerPac' " and it references CuttingPowerPac.dll
I though all powerpacs come with grace period....
This is a bug in Cutting PowerPac 6.00.01 for 30 days trial license.
Workaround is-
1. Go to installed directory - C:\Program Files (86)\ABB Industrial IT\Robotics IT\Cutting PowerPac 6.0\Trial License
2. Rename "Trial License" folder to "TrialLicense" (no space in between)
3. Restart RobotStudio and activate CuttingPowerPac.
Hope it works.
A fix will be provided in Cutting PowerPac 6.01 expected to be released this week.
Post edited by prasant.srivastava on0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
