flexpendant calibration
hi all,
I have a problem with the calibration of my robi, when i start the system and calibrate the system with the flexpendant, the flexpendant shwos me, that the 4,5 and 6 axis not 0 degree.
How can i solve this problem?
Best regards
Best regards
If you are only updating the revolution counters the axis will not be zero, that is not an error.
Regards
Knud Erik Lindberg
Danrobotics0 -
hi
how can i update the axis to zero, because the calibration ist not right ?
You need special calibration equipment to do a fine calibration on a robot. You should contact ABB or your robot integrator. How do you know the calibration isn't right?
How much degree are you seeing on 4-5-6 axis when start robot?0
- 367 IRC5
- 858 RAPID Programming
