Smart Components and creating a new, empty station with PC Interface
pion3k
Hello everyone!
I am facing an issue which is quite unclear to me. What I want to do is to create a new robotic station in Robot Studio which could support the PC Interface (for a network communication) and a service of SmartComponents. I will explain you in steps what I'm doing:
1) I make a new, empty station. I add a robotic arm and create a new robot system from layout where I choose the option for PC Interface.
2) I create the whole enviroment with the robot, i.e. a conveyor belt with a box (it is my object to operate on it).
3) I add and configure a set of SmartComponents. I suppose they are added and configured correctly since I follow the help-guide.
4) When I want to run the program ("Play" button in the simulation tab) I get an error that "Program has been stopped" or something like that (error number 10068).
The thing is that there is no description for a reason of the error. I have been looking for a solution for a while but I could not find any. The only thing I have found is to try to configure the I/O of the system but I have no idea how to do it. Futhermore, I have read that I should use the "Station with existing Robot Controller" but in this case adding or modifying a PC Inteface could brake down the configuration for the SmartComponents and I am limited to IRB120.
Does anybody know how to fix it?
Thanks!
Ok, so maybe I should ask another question which actually could help me much more:If I have my smart components done, a station logic configured, a RAPID code written - should I somehow configure the DeviceNET Lean to make the signals flow possible?I think this is the problem why my station does not execute the orders, i.e. when a sensor detects and object it sends a logic "1" to an input of my system but I don't know why the system does not see the impuls. In other words: I can watch all the I/O of my station. The output of the sensor is directly connected to an input of a robotic station. When there is logic "1" on the sensor, at the same time there is a logic "0" on the input of the robotic station.0
Hi,You should do the connections between the Smart Components and the system in "Station Logic", that you will find in the Simulation tab.Best regards,
ABB Robotics0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
