orientation by Rapid
At this moment I am working on a project were I have to send every position to my Computer.
so now i use
VAR robtarget Target.
For i FROM 0 TO 1001 DO
Target.trans.y:=Target.trans.y-0.1;
MoveJ Target, v, z, tool;
Other than the xyz also the orientation has to be changed every run in the For-loop. because the robot has to move sort of circular. I know the algabra for the angles.But i dont konw how to use q1-q4.
anybody help?
greatings from Holland
  • Hello,
    you can use OrientZYX to calculate the quaternions from angles.
    Target.rot := OrientZYX(anglez, angley, anglex)
    BR
    Peter
  • Hello Peter,
    Thanks, we tried but now we face an another problem. We are simulating a code with some Target 's but those targets are not the same as in real time.
    anybody help?
  • What do you exactly mean by 'those targets are not the same as in real time'?
    Benteler Maschinenbau CZ
