Why is my station did not display the items or objects in its tabs?
Maraiica
When i save a station and close it and then try re-opening it, it has error or the pack and go fail to open. Even the "record to viewer" .exe fail to open.
I your system saved to the local host PC drive ?
Rs have problem when the robot system is saved on a network drive.
Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
I installed my robot studio in my laptop. so i guess it is saved on my laptop drive, If i understand what you mean. Please, help me. i still have the problem. it is getting frustrating. Every time i do a new station, i saved and try re-opening it. It has error. I have to re do everything, every time.
Unpacking station...
Creating systems...
Restoring backups...
Opening station...
Unpack & Work failed
A Support Log will be created. Please report this error using the RobotStudio Support Tool.
Problem can be your firewall.
Regards
Knud Erik Lindberg
Please create a support log file and send to your local ABB representative that can forward your issue to our tech support.
(Start Menu -> All Programs -> ABB Industrial IT -> RobotStudio 5.15 - > RobotStudio Support Tool -> Run Full Scan -> Save Report )
If you don't know who your ABB contact is, you can check on www.abb.com/contacts.
Kind regards,
Henrik
PS. Meanwhile, try to reparing or reinstalling RS. If that does not help, try to manually install MSXML 4 SP3, http://www.microsoft.com/en-us/download/details.aspx?id=15697
ABB0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
