Try, Catch equivalent [moved from RobotStudio]
Patient
Is there anything in RAPID, equivalent to using try and catch statements in C#?
I am trying to read CSV files but want my program pointer to go back to main when it fails to open a file without resetting the robot or acknowledging any errors.
Post edited by Jonathan Karlsson on
you can use the error handler inside each routine to handle this problem.
Example:
PROC ReadCSV()
Open "HOME:" \File:= "Mydata.CSV", logfile \Read;
ERROR
IF ERRNO = ERR_FILEOPEN THEN
!Handle the error
EXIT;
ENDIF
Please refer to the RAPID manual for further information.
Regards
Micky
