Write number in Group Output in ieee-754 format ?
I need to write some parameter in a Group Output of 32 bits in the ieee-754 format. Example to write the value 15 i need to write the num 1097859072.
Any help will be appreciated.
  • Micky
    Micky ✭✭✭
    you can use the instructions PackRawbyte and UnpackRawbyte to convert your value into ieee-754 format or use use the attached function.
    Example:
    Tpwrite "15 = "\Dnum:=FloatToUInt32(15);
    FUNC dnum FloatToUInt32(num Value)
      VAR rawbytes raw_data;
      VAR dnum dnResult;
      PackRawBytes Value,raw_data,1\Float4;
      UnpackRawBytes raw_data,1,dnResult\IntX:=UDINT;
      RETURN dnResult;
    endfunc
    Regards
    Micky
