Communication between two taskt
Hello to all, is it possible in multitask system to call routine in normal task from semi-static task routine, and how. Thanks in advance.
  • By declaring the same variable in both task they will mirror the value.
    Task1
    pers num a:=10;
    Task2
    pers num a;
    Regards
    Knud Erik Lindberg
    Danrobotics
  • Micky
    Micky ✭✭✭
    no it is not possible to call a routine directly from another task, you can only call routines from the same task.
    Regards
    Micky
