A couple of small annoyances with RS 5.6
I have been using the latest version of Robot Studio and have found a couple of small bugs. One is when I right click on a move instruction and select Locate Target, the target is highlighted but the UI no longer scrolls to the selected target.
Issue two was a little more serious for me until I figured out a workaround. I usually sync paths from the VC to the station in the rapid tab. For some reason this button will no longer bring up the contents of the VC. I have found the same functionality on the home tab but it works there. Perhaps these can be addressed in a patch.
Regards,
Xlr8tor
Regards,
Xlr8tor
Thanks for the feedback. Both of these issues (PDD 3053, 3039) will be addressed in version 5.61 that is planned to be released in mid-April.
Kind regards,
Henrik
ABB0
- 367 IRC5
