RS 5.60 Failed to backup
THOD
I am getting the following error message when I try to backup.
"Backup Failed. See output window for details."
The output window says the following:
"Backup failed.Access to the path 'C:\Temp\422f2e84' is denied. 2/19/2014 4:10:43 PM General "
So you would think this is a firewall or folder issue, but it works sometimes and sometimes it doesn't. The folder is created in the temp directory with the name of "422f2e84". All the info seems to be there but it says it failed.
Any ideas?
Please get in touch with your local ABB Robotics Service representative that can forward your issue to our tech support.Henrik Berlin
ABB0
- 365 IRC5
- 84 OmniCore
