ABB robot with LeapMotion
In the following link is available LeApBBMotion.
This pack is composed by and exe file that will install in your computer LeApBBAddin, additional documentation, and a Pack and Go.
Everything will be saved in "C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 5.15\Bin\Addins\LeapMotionAddin" folder
https://robotapps.robotstudio.com/Details.aspx?fileId=501
This is not an offcial product for ABB and its not supported by ABB.
Software from www.leapmotion.com/setup must be installed
1
Just saw this, and was wondering, is there any setup on the robot? Or is it just connect a laptop with this software, and a Leap to the laptop?1
Oh PaleFlyer, I did not see this till now. This is an old code. I do not know if still works,as far as I know LeapMotion has evolved a lot his software. But yes the approach is having Leap connected to the Computer. Robot has PC Interface option so with PCSDK we are able to change RAPID values.0
