Tayssir21543978
As I understand it, "Teach Pendant" is a generic term for a handheld robot control, and "FlexPendant" is the term used by ABB to refer to their TeachPendant (I haven´t seen the term "FlexPendant" being used for other than ABB robots).
when i read the datasheet of S4 and IRC5 controllers, i unterstand that the Teach Pendant is for S4/S4C/S4C+ Controllers and the FlexPendant is for IRC5 controller, so i don't khnow what i unterstood is true or false?!
Thks for your helps
yes, your are right, the teach pendant is for the S4 generation and the FlexPendant is for the IRC 5 generation.
The name "FlexPendant" is used from ABB to differ between a teach pendant with and without a colored touch screen.
/BR
Micky
Thank you Micky0
- 345 IRC5
- 73 OmniCore
- 843 RAPID Programming
- 20 AppStudio
