Two robots
Hey, I am currently setting up a cell for a project at university and need a part to come down a conveyor stop then be picked up by and placed in a jig, then with a separate robot glue a bead round the edge of the part. I have managed to do both in separate cells but how do i get two robots working in the same cell as if I try to add another at the moment it just appears as a component with no robot controller.
thanks
  • Hi, you have better chances getting an answer in the main RobotStudio forum. This is for Controller SDK CTP. I can see that we have lots of posts here which are not about Controller SDK.
    Before I simply help everybody by moving them over, I would like to ask you if there is something in the user interface in the forum application that would make it easier to see the difference between the different forums
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
