Problem of creating a new robot
jerry-licao
Hello everybody:
When I creat a new robot,how can I built a system with it and program as ABB standard robots in the library? Thanks
Can anybody help? Thanks0
At the top right of robotstudio there is a blue questionmark, open the robot studio help.The second chapter explains how to build a stationRobWelding
The Netherlands0 -
Thanks Sjoli:Maybe you mistake me; I mean that when creat a robot(2 axis for example),but there is no mediapool for it,so we cann't build the system.0
I creat a systerm using external axis wizard , but there is not any mechnism in the list,why?0
To use the external axis wizard you need to have a system. The wizard will not create a system for you, only configure one to use some external axes.
So, first step, create a system and make sure to include enough external drives for your mechanism. Then you should be able to use the external axis wizard.
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 10 AppStudio
- 105 Collaborative Robots
