Servo Guns and RS
Hello, I have set up a system (In preparation for a project we are doing) with a 6640 on a track with 6 working servo guns. created a tool changer and tool stands using smart component’s and imported servo gun moc files. However, when i load the 6th moc file, the system complains that servo gun 6 is not connected to a rapid task. I can act and deact 5 guns individually (all on one drive) and attach and detach etc so as to dock on and dock off each gun, using standard code. Is there a limitation with RS 5.60 (tried 5.61 also) to only allow 5 guns?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
  • Hello Pat,
    It sounds as if you are getting RobotWare error, and in that case it might be that there is a limitation in RobotWare. As you seem to be an ABB employee I would recommend you to log a RobDesk issue about your problem.
    Kind regards,
    Henrik
    ABB
  • Thanks Henrik.  Have logged issue with RobDesk
    Kind Regards,
    Pat
