Simulation running at ridiculous speed
Hi, the simulation in RobotStudio somehow turned to be running at a ridiculous speed. Any idea why is that?
These are my settings for options.
Any idea guys?
  • It should be the Free Run setting.
    Time Slice is the default setting.
    Hi, John.
    It is free run thats ticked.
  • I have managed to get rid of the problem by installing the latest version of RS.
    Reinstall RS = A fix to everything.
  • It is the Free Run that causes the problem. You need to be in Time Slice to fix.
    BR
    BR
    Thanks for reply. I have tried everything before re-installing, I guess it is just a set up thing for this particular machine.
