unusual problem creating station in RobotStudio
Agge89
When I try to create a new empty station, I receive an error message:
RobotStudio .NET exception: Could not find a part of the path 'C:\Windows\system32\RobotStudio\Code Snippets'.
And the station is not created.
I have previosly installed robotstudio on other computers, but there are never a folder called RobotStudio in system32. This is an installation on my computer at work.
Thanks in advance for any help
Best regards
August
Have you been playing around with Code Snippets? In some cases when there is a syntax error in one of the snippets we have had problems creating new objects in RobotStudio.
Please go through the snippets in the path [%userprofile%\My Documents\RobotStudio\Code Snippets] (copy&paste into an Windows Explorer).
If you have no snippets that you care about then we could delete and repair that folder. Which version of RobotStudio are you running?
John
Developer Center0 -
No, I just installed robotware and Robotstudio on my work computer. After that, without playing around with anything, I try to create a new station.I am using the newest version, 5.61.0001.But why is it looking in the system32 folder for code snippets? I looked in my other computer where I have previoulsy installed Robotstudio and I couldn't find any such directory.I don't really know what code snippets are for. I therefore have no code snippets that I care about.Best regardsAugust0
