Problem of creating a new robot
Hello everybody:
        When I creat a new robot,how can I built a system with it and program as ABB standard robots in the library?  Thanks
  • Can anybody help?  Thanks
  • At the top right of robotstudio there is a blue questionmark, open the robot studio help.
    The second chapter explains how to build a station
    RobWelding
    The Netherlands
  • Thanks Sjoli:
         Maybe you mistake me; I mean that when creat a robot(2 axis for example),but there is no mediapool for it,so we cann't build the system.
  • I creat a systerm using external axis wizard , but there is not any mechnism in the list,why?
  • To use the external axis wizard you need to have a system. The wizard will not create a system for you, only configure one to use some external axes.
    So, first step, create a system and make sure to include enough external drives for your mechanism. Then you should be able to use the external axis wizard.
  • thanks   Jonathan,  I understood.
