Show joint angles
A long time ago believe I found a way of showing the individual Joint Angles of a virtual ABB 140 while I run a simulation / execution. I can't find that option in 5.61.
My problem is that some programs utilize almost all of J6, and I need to find out where my limits are.
Kind regards
  • Hi,
    In the "Mechanism Joint Jog window" you can see the individual joint angles during execution.
    Regards,
    Anders
    ABB Robotics
  • Thank you Anders.
    It is quite difficult to find - it seems like it can be only found by right clicking the robot and pick it.
    The explanation in the manual seems correct as well.
