communicate variables among multiple robots
If you have multiple robots on 1 controller, you have 1 task per robot.
You have to declare your variable in each task with the same name. but you can only declare a value in 1 task.
exemple:
T_ROB1: PERS bool b_test:=False;
PERS num n_test:=5;
T_ROB2: PERS bool b_test;
PERS num n_test;
if now you change b_test in T_ROB1, it also change in T_ROB2 and vice versa.
BR
Peter
1 -
Thank you very much, you´ve been very helpfulPeter1 said:Hello,
exemple:
PERS num n_test:=5;
PERS num n_test;
BR
Peter
- 365 IRC5
- 84 OmniCore
