About GripLoad Loaddata;
Hallo everyone,
i have a Problem. I define an Loaddata Array als PERS.
PERS loaddata Muffe_Load{47}:=[[03.62, [0, 0, 0.4],[1, 0, 0, 0], 0, 0, 0],
[04.66, [0, 0, 0.4],[1, 0, 0, 0], 0, 0, 0], .......];
But it is not working with Gripload.
PROC GreiferClose()
Reset DO10_0GripperClose;
Set DO10_1GripperOpen;
WaitTime 0.5;
GripLoad Muffe_Load{12};
Everytime Shows the follow Message:
41442: Reference Error
Description
Task: T_ROB1The reference in argument Load is not an entire persistent variable. Program Ref. /VenConfig/Greiferspannen/GripLoad/96
Actions
It is not possible to use record component or array element in arg. Load . It is only possible to use entire persistent variables for Tool, WObj or Load in any motion instruction.
Hello,Did you forget to put TASK before creating the loaddata? as in:TASK PERS loaddata Muffe_Load{47}:=[[03.62, [0, 0, 0.4],[1, 0, 0, 0], 0, 0, 0],
This works for me...
I got this:
TASK PERS loaddata LoadGripper{2} := [[0.001, [0, 0, 0.001],[1, 0, 0, 0], 0, 0, 0] , [0.001, [0, 0, 0.001],[1, 0, 0, 0], 0, 0, 0]];
GripLoad L0adGripper{1};
This works for me
Hallo B_Baan,
Thank U for your Answer;
I have copy your code. But It does not work for me. It is same error.
Now i define a between-pers loaddata . It called "current_load"
Verytime i update this data from my Loaddata-array. It worked!
PERS loaddata current_load:=[5.23, [0, 0, 0.4],[1, 0, 0, 0], 0, 0, 0];
Pers num MuffeNrCurrent:=0;
Proc Gripperclose()........MuffeNrCurrent:=DnumToNum (GInputDnum(gi17_22MuffeNr));current_load:=Muffe_Load{MuffeNrCurrent};
GripLoad current_load;
endproc
