Custom Buttons on GTPUMessageBox
Hello all,
I would like to show a message box containing buttons with custom text (not OK, Cancel, Yes, No). This is possible with some of the overloaded methods of GTPUMessageBox.Show, but I don't know how to handle the click event of the custom buttons.
Can anyone show me how to do it? Some code snippets, maybe?
Thank you,
Yolanda Casas
  • Hello again,
    Finally I found the way to make it work... I will post some sample code in case it can be of use to anyone else:
    GTPUMessageBox.Show(
    this, new MessageBoxEventHandler(HandleSelectionResult), "Please chose A or B:", "Select option", ABB.Robotics.Tps.Drawing.TpsIcon.Info, new string[] {"A", "B"});
    void HandleSelectionResult(object sender, MessageBoxEventArgs e)
    if (e.ButtonText.Trim().CompareTo("A") == 0)
    // Do stuff corresponding  to A
    else if (e.ButtonText.Trim().CompareTo("B") == 0)
    // Do stuff corresponding to B
    *Note the "Trim()" operation on e.ButtonText before the comparation!!
    Regards,
    Yolanda Casas
