Variable accessible in multitasking
I am using multitasking and there are currently 2 tasks in my RAPID code. How can I share a variable declared in 1 task and use it in another? I thought PERS var declared in a module is global but I got Reference Error when I applied the change. Can anyone help please?
Thank you.
  • graafderk said:
    You have to declare the variable in both tasks. For instance:
    task 1:
    PERS bool testBool:=TRUE;
    task 2:
    PERS bool testBool;
    Thank you!
  • J.C.M.Castillo
    edited February 2016
    I had the same problem. Thanks for de solution.
    But I have other problem about global variables.
    I can't share a variable type SPEEDDATA in two tasks.
    I always get a Rapid error.
    I have used this code:
    Example 1:
    task 1:
    PERS speeddata speed:=V1000;
    task 2:
    PERS speeddata speed;
    Does someone help me?
    Is possible to do that?
    Thanks a lot
  • Hi V1000 is a constant variable declared in the system so you need to
    either declare your variable with values or assing them later in the program
    Per Svensson
    Consat Engineering
  • Thank you.
    I am going to test it...
