Check for simulated signals
scottATG
Is there a way in RAPID to check for any simulated signals before a routine starts?
<p>Hi,</p><p>you can define a system output which reports the simulated signals (Blocked I/O).</p><p>In addition you define a "start" and a "restart" event in the system parameter and in the connected routine you can set if the output for the simulated signals is set to high.</p><p>if yes you can display an user information.</p><p>BR</p><p>Micky</p><p> </p>1
Cheers, Ill have a go0
- 367 IRC5
- 858 RAPID Programming
