Painting PowerPac 6.0 - setting Conveyor Tracking parameters problem
I followed instructions from Release notes for Painting PowerPac how to
set Start Window Width, but still when I start simulation, I get
warning: The workobject will never connect since the Start Window Width
is 0! Please change the value in the 'Configure Conveyor Encoder Unit'
dialog.
This is a know bug in version 6 of the PowerPac, its actually mentioned in the release notes. They only way I've found around it is to set the values using RS 5.61 with the relevant PP but if you've saved in RS6 then sometimes you can't open in a an older version.....
5
