DropWObj before time
I have followed the conveyor tracking tutorial and later setup a station with an IRB5400. Below you can find my path
MODULE Module1
CONST robtarget Target_10:=[[-0.0031509,-408.212057437,1891.611066019],[0.488612588,-0.511133808,0.511133714,0.488612623],[0,-2,1,0],[9E9,9E9,9E9,9E9,9E9,0]];
CONST robtarget Target_20:=[[-933.561708337,-408.212509903,1891.611721475],[0.488612571,-0.511133148,0.511133704,0.488613342],[0,-2,0,0],[9E9,9E9,9E9,9E9,9E9,0]];
CONST robtarget Target_30:=[[-0.003087165,-519.824663011,1891.610671637],[0.489760153,-0.510034307,0.5100343,0.489760156],[0,-2,1,0],[9E9,9E9,9E9,9E9,9E9,0]];
PROC Path_10()
ConfL\Off;
MoveL Target_30,v1000,z100,Reiter_Gun_150\WObj:=wobj0;
ActUnit CNV1;
WaitWObj wobjCNV1;
MoveL Target_10,v1000,z100,Reiter_Gun_150\WObj:=wobjCNV1;
MoveL Target_20,v1000,z100,Reiter_Gun_150\WObj:=wobjCNV1;
DropWObj wobjCNV1;
ENDMODULE
Here is what happens when I run the program:
As you can see, before robot returns to Target_10, conveyor drops the object. Can anyone explain to me what I am doing wrong?
*Run this on RS6.0 and R5.61.
*Checked maximum distance in encoder unit.
Thank you for your time.
M.Bahadir Boge
The reason is that you have a big zone in the last motion instruction. The program pointer is usally always ahead of the motion pointer. So change the zone in your last instruction to a fine instead of z100Per Svensson
Consat Engineering1 -
Thanks for the answer.0
- 364 IRC5
- 83 OmniCore
http://youtu.be/C9o0OOtVsPE
