ERROR: 10068: Start Program; Description: Unable to start program for task T_ROB1 ;
Hello everyone, I cannot figure out why I always when I try to ''move along path'' get error : 10068: Start Program. I am new in robot studio. I defined workobject, targets and path. Checked the reachability and configuration, everything seems ok. I also can see robot or tool at target in right position. I give you link of picture http://shrani.si/f/22/d9/i2oV9du/error1.jpg I also noticed that I cannot run the simulation (I get the same error). Thanks everyone for answers!
  • Neily03
    Neily03 ✭✭✭
    Have you selected the routine you want to run in Simulation setup after syncing to the VC?
  • Hello. I made a similar in RS 6.01.01. Move along path worked fine. Did get the same error when trying to do the simulation after synchronizing to Rapid. This was because I did not set an entry point for the simulation. Normally that would be your "main" routine. In RS 5.61 and RS 6 you can set the entry point from the Path tree.
  • Neily03 : What exactly do you mean by that? Where can I try to do that? j_prolux I cannot select entry point in the program!? See picture below: http://shrani.si/f/38/iW/2HTyQo17/2.jpg
  • Go to Rapid tab, and verify your code, and then send changes to virtual controler.
  • You can define the entrypoint from the context menu of a path, or from the Setup Simulation window in the Simulation Tab. Both options are displayed in this image: image
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • I use RS version 5.61 and I dont have this option here. I can chose Entry point at Setup Simulation and I did it. It didn't helped me. Error still accurs! http://shrani.si/f/2x/tM/40cBiJQc/222.jpg
