How to Play the program with ArcLStart, ArcL, and ArcLEnd
WuYue
Hi, I am using Robotstudio 6.01 and ArcPower Pac 6.0. I write the RAPID program contains ArcLStart, ArcL, and ArcLEnd. However, when I play the RAPID program, the error: 'Arc ignition supervision signal not set at start of welding' always show. Any one has idea on this?
You should block Arc in the virtual flex pendant Arc application or simulate the Arc ingnition signals using for example SmartComponentsPer Svensson
Consat Engineering0
- 367 IRC5
- 858 RAPID Programming
